Hmm...not to confuse this anymore now that some SWR issues have been sorted out...
Remember you have an HD (High Drive) amp, it doesn't "sip" coffee to wake up in the morning...
IT guzzles it...
What used to need several mW or even a Watt, now needs a little more oomph so that means the SWR problem will need a different approach than a typical 1 Pill driving 4 type of scenario.
You have babies requiring milk...and they need to be fed to produce output...
Yes, output...you didn't specify...
So the SWR to a High Drive Amp will look like it's "not right" - because of the input network and the dynamics you're dealing with...
Too low - you're hitting a wall - they can't conduct their full cycle - the RF signal arriving is too weak...
Too High - you get slamming and FM-ing - and ... see above - top right...
So if you haven't really noticed, or you were just humming a tune as the muffler to the Chevy slowly eroded and finally fell off - you're left at a Stop sign wondering if the Cop on the other oncoming lane - whom is signaling you to go, is going to notice the extra noise...
So the High Drive amps are little more finicky on the kind of power levels, their dynamics (or swing) and the tuning you have to implement that allows for low- to high power loading swing to even work. In fact it's worse than s simple 1 X 4 - you know when you overdrive it, but Ooh! Does it float along nicely when it's just using 2 watts swinging 8...
The tuning network needs some help then when - YOU SEE SWR PROBLEMS WITH THE AMP ON ACCEPTING INPUT FROM THE RADIO - not a big deal but you will have the law of diminishing returns - the power dynamics needed to the High Drive Amp to use and need to make it swing are considerably different than a regular 2-Pill or a Modulator. The Network can be tuned for either a high power no swing output - or - low INPUT-power but limited high-swing levels - both are possible - you just can't do both at the same time...remember the SWR problem - you have to adapt an input network per pair of pills. So if you have 4 Pills, you will divide and conquer needing 4X the effort in power delivery than a simple 2-pill input.
IT guzzles it...
