I traded for a dx 1600 and it had 4 blown transistors,Question I have removed and checked the gain on the 4 that were good hfe of around 30 on all four,I have 4 new old stock red dot's that have around the same gain at 35-40 hfe..Would there be an issue dropping the red dots in to replace the 4 bad ones?Or would it be better to order 8 new hg's matched to put in it?I have replace all the 10 ohm resistors and there was no damage to the combiners and none to the bias resistors..Just took out 4 of the toshiba's..Thanks
