Yea that is entirely possible. I can check again tonight, before I move the radio off the work bench. As an addition I just checked and now I am seeing 13.8 VDC. That was my bad!Could it be you're using the chassis for the negative side of the meter probes? Better to use the circuit ground than the chassis on the original versions.
What do you want a picture of?
