You can try this
That is......uhhh I have never.....welll ummmmmI can now report... I've seen everything. Thank you.
Not too hard to start with, but it does get harder the higher it goes. If you have to do it very often, you wouldn't like it.
(Dang sure'll build up some upper-body strength though!)
Guying.
It depends entirely on how much support is needed by the pole (and what's on it), and how much is provided by the house. Guying any pole is a good idea! That's more a mechanical property than anything else. It's very seldom that there's ever too much guying, it's just good sense, you know?
I just put up my 30' pushup pole.
What I did was took 2 -1 1/2" x 3' metal pipes and drove them in the ground with the push up pole sandwiched in the middle and drilled a hole through all and put a rod through.
I had the 30' pole with the 18' antron 99 antenna lying on the ground and just stood it straight up quick and easy.
