I bought this simple 9:1 unun matchbox.
Is it okay to run the antenna wire (right side) up say 6-8' then make a left, go over say 30' to a tree (on an upward slope)??
I've heard you need to orientate it so the antenna wire goes straight out in the direction and that going up is not preferred.. But I've seen half-square end fed drawings..
Here's my proposed layout
Will be fed with a 1:1 balun and counterpoise wire(s) as well. Using 25'+ of LMR-240 to tuner and radio.
Opinions, thoughts..
