That is pretty much the way I see it Native. Then if the GPK does its job, you should be good to go.
Rfoverlord, this does not mean that these antennas are no good. I have a Ringo that is hard to tune and changes tune if you move it a foot, up or down, but works like a champ as far as signal goes to some local locations.
By stopping the errant currents, and providing a good raised ground path, maybe you will eliminate some possible losses due to the currents that would otherwise get into the earth, plus it hopefully will improve the signal and its strength into a pattern more close to the horizon by not skewing the radiated pattern of the vertical or beam, plus maybe it might reduce local TVI potential in the neighborhood. If it does any or all of this, it sounds like a plus for me even with the trouble it takes.
But that they work in spite of these approaches is a testament to how easy we have it in our hobby.
Its sort of like tuning your auto and keeping your tires inflated well, it will probably get by even if you don't do it.
