CB Mobile Beam Antenna - End Fired Phased Array Antenna (Amazon)
This must work, why else would the "key-down" competition guys build these antenna setups?
Please share some thoughts, ideas, & an opinion on the topic.
I have not looked into the theory behind this setup, but this link tells me I might be onto something here!?
The description on Amazon goes on to describe how the idea was taken from the "radio handbook"? (ARRL?)
My real question is how is this not just a co-phased antenna setup if "both elements are driven" as the description reads?
And more importantly how can I learn to build something like this:
Where do I find the formula(s) for the spacing... And yes you can just tell me to go read an ARRL antenna book if you like.
Maybe i'm waisting my time trying understand and recreate these style of rigs, but it is part of CB radio that I want to learn more about.
Thank You
Is this application snake-oil, or can I really learn how to build a "key-down" style van for $3.99 and have more gain than an Antron 99?...details as to how this antenna system and how and why it works!
Our CB Shop in Baltimore Maryland took this design from the radio handbook, adapted it from theory to real life and this baby just blows the socks off of anything we have ever seen! SWR test on the final install showed 1:1 over 4 MHz wide, basically 1 to 1 all over the place! When using 1/4 wave stainless steel whips power limitations is UNLIMITED, it will handle anything you can give it - PERFECT FOR CONTEST! And the BIG QUESTION, ARE BOTH ANTENNAS DRIVEN??? YES! Both are driven! Most guys just ground the rear antenna to make it act like a beam on a house, but that is not how its done, looking at the antenna pattern on the cover, you can see that when BOTH ANTENNAS ARE DRIVEN the FORWARD POWER AND GAIN IS GREATLY INCREASED! Install is simple just 2 standard ball mounts a set distance apart! It is this distance that does the PHASING and this distance is set by the VELOCITY FACTOR of the coax. It's easy and its all in the plans! Thanks for looking, Have Fun 42,,,
Thank You
