Mobile End Fired Phased Array Antenna
Playing with the end fire array and forced current feed method of phasing is fun.
The moxon will have better results most likely
I've made a Moxon for uhf. the concept is a folded dipole with a folded reflector. Can't think of how you would use that vertically as a mobile antenna. No doubt it was a heck of alot easier to tune then a standard dipole without a balun.
BTW tons of Moxon calculators on the internet.
Reactions: Junebug
No moxon on a mobile. I have a stealth location i just want to mess around with both styles of antenns on a metal roof.
In that case, MMM has a DDRR antenna on his mobile (it looked like a military issued suburban or a one that was painted in camo colors). I remember seeing it on youtube. Food for thought. if I find the video I'll post it on this thread in the future.
Reactions: Junebug
  • @ Geoexplorer69:
  • @ Geoexplorer69:
