Receiver damage is more likely if you get too close to a high-power RF source.
Had a group of OTR drivers who liked their HR2510 radios back in the day. The power switch on the radio only removed power from the low-power parts of the radio, receiver and switching circuits. The final and driver stages are always "hot" so long as the power cord is connected to 13.8 Volts DC. The drive voltage to the base terminal of each one turns it on. Or keeps it turned off.
Turned out that leaving the final transistor "plugged in" to its source of DC power is safe until the RF energy coming down the coax from the antenna reaches a voltage threshold that turns on the final transistor's base terminal. Of course the radio's low-level circuits are all still turned off, so the final becomes a RF oscillator. Now it provides its own drive current to the base circuit after the nearby radio unkeys.
It continues to oscillate at some random RF frequency until it overheats and smokes numerous components in the RF final circuits.
Some drivers would find only a smoke-filled cab and blown fuse on the radio. The lucky few would hear a screech from the speaker, and see a pegged meter. Pulling the power cord would sometimes rescue that radio before it could go critical and melt down.
Oh, and never, ever leave your FT-101 radio connected to an antenna while the radio is unattended. Had a customer who couldn't understand why his FT101's MOSFET antenna-amplifier transistor kept blowing out. Until one day the channel 6 operator who drove by that time of day keyed up close enough to bleed the TV and stereo. Harry's idiot light came on, and he went to the basement to check his baby FT101. Sure enough, the receiver had gone deaf again. After getting it fixed this time he decided to unhook the antenna from the radio when it wasn't in use. Didn't have this problem again.
