ERF7530 equivalent replacement?
This is an upgrade replacement ...... ERF9530 ..... I purchased 4 of these to replace the ERF7530's in a Palomar HD450 FET amplifier ......
https://www.rfparts.com/rftransistors/transistors-erf/erf9530.html
ERF9530 RF Power Mosfet Transistor, 100 Watts PEP, 30 MHz, TO3PN Case
The ERF9530 feature new silicon wafer designs with greatly improved quality and durability. Palomar’s new wafer technology creates a new level of ruggedness for these RF power MOSFETs that are now able to withstand all adverse conditions - high heat, high VSWR, high voltages and current levels.
The ERF9530 is a drop-in replacement and upgrade for the ERF7530 transistor and features a new TO-3PN insulated package for the mounting screw. The ERF9530 is conservatively rated at 100 watts PEP.
FEATURES
• High Power and Economical:
Pout > 25W (100W PEP)
Gp > 10dB @ 12.5V, f=30MHz
MFR: Palomar
Yes but CB is 27mhz not 30mhz and the old 2SC1969 had a minimum gain of 16db and the older lower wattage driver and finals in AM only radio's often had minimum gain figures in the 50db to 150db range @27mhz no less.
I would love to see the test circuit used to establish that gain. We do not have a real datasheet either we have some cut and paste document that is a little light on data!
I always thought the MRF477 was a little low on gain but this is absolutely pathetic! It is no wonder these radio's are often using 2 driving 2. On top of that I have never seen a radio with 2 driving 2 that could actually get 100w PEP per device only counting the two finals so not expecting 400w pep. I am sure you could get it for short term service but ZERO durability. The radio's chassis cold not take that power output level and the heat sink can not dissipate that much heat! Look at how many mosfets the 2970N2 had to use to get the factory rated 100w power output and have durability.
Also no mismatch swr at any give phase angle is included either and that is kind of important for rf finals. You could dead key a 2SC1969 for a couple of hours with no antenna hooked up at all and not blow it. On the other hand an SWR over 1.3:1 scares people to death and 1.5:1 is mosfet popcorn time!
What good is a 100w pep if the radio and parts can not survive at that level for long? What good is all that wattage with very little gain. In a perfect world you would want at least 4 as finals not 2 driving 2 of those to make 100 watts pep and you would absolutely need swr protection to fold back power if the swr climbed and 8 would be even better. You would need a much larger heat sink and fans. It would be even better though if they would just put a single MRF454 as the final in these radio's. We would have decent power, decent gain, and fantastic durability. It could be an HG 2879 not as durable but a lot better than non-rf mosfets. If people would accept realistic power for those radio's something like 2-4 of the RD16HHF-1 are actually RF Specific mosfets that replicate the old 2SC1969 fairly well in terms of wattage and gain. At $5 each they will not break the bank. At $5 each though that is about 5X the cost of the junk mosfets currently in use maybe as much as 10X more when you look at the huge number's OEM buy these parts in.
Oh and I am so much talking about Palomars replacement as I have not tried these yet I am talking about the cornucopia of non-rf mosfets used by all your cb radio's and black box/rice box radio's!
Reactions: dr.spin and NZ8N
Those things are really expensive and most of them run on 50 volts. For a mobile not real feasible.
On Fleabay, there is a Canadian seller that has them for $132/OBO/free shipping. That means that makes it approximately $.10/watt. Woof! Of course the problem is to build a PS for 50v. Means that a 2:1 stepdown 50/60v xformer would need to be beefy enough to supply that @~30A - or better. Unregulated supply probably wont cut it. But if it could; then large bridge rectifier and then a large cap bank to keep out the ripple could make that happen. Interesting. No dangerous HV needed. Makes it far safer too.
Yep, I got that. Great for a base unit, but not so good for a mobile use.
I have some of the newer ERF-2030+ MOSFET's ....... I am going to install them in a Stryker SR955 HP with a Palomar MAX MOD .......
I'm retired and enjoy repairing / upgrading radios and amplifiers.
I need one more piece of equipment for my bench, a spectrum analyzer scope .......
Anyway, I want to see how the new ERF-2030+'s perform ...... I have had good results with the FQP 13N10's ..... and also of course the IRF520's .....
I have an "old technology" RM-KL203p W/ original mosfets, that has routinely withstood swr conditions of over 2.5:1, even 3:1, it gets hot but keeps ticking, haven't seen the performance fade, after it cools back down that is.
Reactions: Tallman
You are lucky. I have seen amps fry without a transmitter attached or even being keyed up.(Infantile failures do happen)
65V+ units are much better than they 50V units. You can use them in mobile application even Luke aka BBi puts them in mobile units. Ideally, a base station is an even better application. Compared to the price vs performance of bjt's they are a fantastic value. Since I have 16 bjt PCB's I am not jumping ship anytime soon.
Leapfrog 3:1 is nothing LDMOS can take anywhere from 68:1 to infinite and that is at all phase angles.
