Thanks for the pic!
Hmmm, if it is a "W2DU" balun, I would have expected a string of ferrite beads over Teflon coax as that is the only configuration Walt ever really promoted that I'm aware of. Unadilla also sells "W2AU" baluns that IIRC are the conventional transformer type of blauns.
From what I've seen, "W2DU" baluns encased in PVC are characterized by being much longer than their transformer counterparts.
I have a Van Gordon balun that is on the 40/80 fan dipole we use for Field Day that is of the transformer type that works well.
I just received three of the W2DU balun kits from the Wireman that include fifty #73 beads, a 16" length of RG-303 cable, and a copy of the March 1983 article by Walt describing the choke balun.
For his W2DU "baluns", Maxwell specifically used ferrite beads over RG-303 coax, although you can get the same effect with putting ferrite beads on other types of coax as well.
The DB
I hang my head in shame!! It is NOT a W2DU balun it is a W2AU balun!! Small change of callsign but BIG difference. I stand corrected. The callsign was originally on the housing but has since long worn off and I was sure it was a W2DU however I must stand corrected. As soon as I saw the callsign W2AU it clicked. My apology to the masses.
