Export General Lee only putting out 10 Watts... Please help!
Logi345
Nov 19, 2018
14
42
I have a general Lee that’s only putting out 10 Watts. I’ve checked the transistors with a multi meter, they test good as in they’re not shorted but is that a proper test or do I have to purchase a transistor tester? Any help would be appreciated thank you.
Trying to find schematics that list the voltages on each circuit within the radio. I would like to know what voltage is supposed to be applied to the finals when you transmit.
Hmmm...Not sure if Occam's Razor is broken or another alert is beginning to flash...
Here's your board number
Since General Lees' and the like are under the Galaxyh/RCI umbrella, you might want to try there or at least go to CBTricks.com and see if Galaxy has the board for you and work accordingly.
Seen that tape before - just not sure where ... on YT.?..:)
Yes, that was a simple trick I never thought of.... It’s a great idea for sure.
i’ll do some more searching tomorrow, thanks guys.
The driver MOSFET is the same as the finals.... That doesn’t seem right.
It's not right but, it's exactly like the builder intended because these are not transistors designed with RF stages in mind. In those cases you would have a lower power, higher gain transistor designed for the driver, and something more robust as the final, perhaps having a lower gain. Today, you get repurposed switch mode power supply transistors, being misused as linear RF transistors and they are horribly unreliable as a result. No reputable manufacturer would be caught dead using the junk they put in the back end of CB's today.
Reactions: Slowmover and bob85
It's not right but, it's exactly like the builder intended because these are not transistors designed with RF stages in mind. In those cases you would have a lower power, higher gain transistor designed for the driver, and something more robust as the final, perhaps having a lower gain. Today, you get repurposed switch mode power supply transistors, being misused as linear RF transistors and they are horribly unreliable as a result. No reputable manufacturer would be caught dead using the junk they put in the back end of CB's today.[/QUOTE
It’s my friends radio, he had someone supposedly put new finals in it so I wasn’t sure if he installed the wrong ones. He also put a voltage regulator in with no heat sink grease, the side of the radio was getting so hot you could barely touch it and by that time the radio would flicker on and off.‍♂️
It’s crazy the number of people that think these type of radios are any good.... I mean they are complete trash! As soon as you touch one thing, something else falls apart. It’s like they put the damn things together with hot glue and toothpicks!
The simple truth is no amount of money can purchase a decent 10 or 11 meter radio today. The main reason is there is not a single manufacturer left, that is willing to build a proper final stage, with any part that was designed to do this job. Buyers should be mad as hell that these manufacturers won't spent $10 for the right parts on a 25 watt radio and about $40 on a radio making over 100 watts, that could cost up to $1,000.
