EZNEC help please
Looks like you have it dialed in perfectly. I used a hairpin match on my 6m yagi as well. I used a halfway coaxial balun along with it and the match was similar to what you show. My configuration is six elements on a 17 foot boom but it an OWA design...... Optimal Wideband Array......so it just fits in that 17 foot boom. Reflector to driver spacing is only about 27 inches and driver to the first director is about 16 inches. This assures heavy coupling and creates a nice tight pattern on a 17 foot boom. I used an old Wilson Shooting Star for parts so it is really heavy duty for 6m.
This is my first Yagi build and my goal is to get a bit more gain over the Moxon I use now while making the antenna as lightweight and low wind load as possible. It won't be very wide-banded since all I'm interested in is the SSB portion of the band. As of now the boom will only be 82" long.
If the final numbers are anything close to the model, I'll be as happy as a pig in you know what.
7 3
I'll add this in regard to design...You build for MAX forward gain.
I qualify with this...Good Back Scatter on 6m is a plus IMHO. I can think of only a handful of times where I wanted to reject/attenuate someone's signal on 6 meters (after 15 yrs on 6m)...Plenty of band space ...I'll move :cool: (or they will!!!) :) Just saying... Forward Gain...forget the back door/ 90+ times out of 100 you want to hear back scatter:LOL:
I'll play some more and see how high I can get the gain. Other than local noise, which isn't bad, I don't have anything I need a big F/B for.
This is as much gain and as low F/B as I could squeeze out while keeping within my weight and boom length limits.
Screenshot (92).png Screenshot (91).png The dBref gain is Free Space dBi minus 7.55 dB which is the Driven element gain modeled over the same height and over real ground as the Yagi was modeled.
After playing with the Hairpin dimensions:
It's been fun playing with and learning the basics of EZNEC. It will be interesting to see how close to real life the modeling dimensions turn out to be.
7 3
