Notice here recently my fan on my tnt 350hd slows when keyed/talking?
Any ideas and is this an easy fix I can do?
Check to make sure the guys at X force did not forget to wrap the fan leads through a toroid core to stop RF from getting into the fan.
3-4 wraps on positive lead, a .01 or a .1 from positive negative. If that doesnt work, try the foil tape over the piece where wires go into bottom of fan. depending on location, sometimes those fans are only a 1" from output transformers and it needs the sheilding.
