Modeling is not among my skill sets. I don't see where they usually take in some data that might be relevant . . . but I don't know
One observation in real antenna comparison between the EFHW 1/2 wave, and the 1/4 wave GP, and the 5/8 wave GP is referenced to the ways that folks commonly seem to employ radials with each of them, perhaps because of the matching networks.
The 1/4 wave GP isolates the vertical from the radials completely and uses the separate feed line conductors on each part, very similar construction to a dipole.
The 5/8 wave GP isolates the radials from the vertical, but re-establishes a grounded connection between the radials and vertical radiator through the matching system, inductor coil, loop rings, or trombone, etc, all of them providing a positive ground between all parts of the antenna.
Yet, the EFHW often simply gets a set of wire radials attached to the bottom of the antenna without respect for the type of matching network employed at all.
"Hey, just attach three or four slanted/horizontal wires to the bottom of the antenna and make a GP out of it."
Perhaps consideration for HOW the radials are integrated into the system would make a difference in results?
Just asking . . .
When I experimented with an EFHW with and without GP I was careful to follow the same practice I used with the 5/8 GP - isolate the antenna halves from each other, provide positive ground potential through the matching network, and keep working to tune the radials lengths, tap point on the matching inductor, and amount of capacitance by adjusting the variable cap in the matching device until the resonance of the antenna, the SWR match, and the best response from the antenna seemed to coincide.
I believed then, and have seen nothing to persuade me otherwise, that I detected a performance difference in terms of potential gain improvement over the antenna without the radials. It was the best 1/2 wave I had ever used. Not having any way to prove this beyond my experience I simply filed it away as a possibility I trusted was possible to duplicate.
Just asking . . .
