Wow...OK She works - lock n' load ok, don't mess with it - keep the SWR low on it and let her rip...
50 amps? 5' Firestik? Hmm, might need metal to metal antennas - Fiberglass (Fireglass) will cook at those wattage numbers...
Might want to re-check and if needed rebuild the electrical to handle 50 amps off the battery that thing will certainly need. New cables - positive and negative (clean up that ground lug on frame especially) Even Alternator too will help, but a newer battery upgrade - even more...No less that #6 AWG too, route to, on that puppy. Bolt that amp to the frame too - at least to the Dodge - it' needs all the help it can get...
You got something that will kick butt if done right...
