Fire Ring
skirk55
Nov 6, 2006
95
Bucks County Pa. 18940
I purchased a Coax Cable With A Fire Ring and when I went to install it I don't know how it goes together. :x I am putting it on a Hustler HQ-27 Antenna. Can someone please help me? I cant believe there were no instructions! I must be the one in a million who has never used one! :oops:
If I recall correctly, that is designed for a certain type of mount....meaning if you don't have that mount it's no use.
....and BTW, you can check the install easily....check outer braid to ground, and center conductor to antenna.
