whatever professional. I know what my equipment does and what other equipment does. But if you want you can come to my house and operate my 99v and both 980's then we can hook up my early president grant which is a drifter and see not all galaxys are bad. I got 2 yaesu ftm 7250 dr radios 2 meter 70 cm dual band 1 is great 1 has been back to yaesu twice for same problem. Does that mean i should say avoid yaesu too?Not going to get into a pissing match with a typical CBr. I said Vintage side mic 148 or Uniden Grant. I'm going to piss off many of people with this statement. GALAXY radios Suck! Chinese junk. Cheap plastic knobs. Echo, roger beeps, drifting all over. Junk.
Agreed. Not all Galaxy radios are drifting pieces of junk like the early 959. Different radios, different versions, different results.whatever professional. I know what my equipment does and what other equipment does. But if you want you can come to my house and operate my 99v and both 980's then we can hook up my early president grant which is a drifter and see not all galaxys are bad. I got 2 yaesu ftm 7250 dr radios 2 meter 70 cm dual band 1 is great 1 has been back to yaesu twice for same problem. Does that mean i should say avoid yaesu too?
you sir are correct .Agreed. Not all Galaxy radios are drifting pieces of junk like the early 959. Different radios, different versions, different results.
Just pays to do some homework before buying.
On another note you may want to be careful how you address other operators here whether they be cb or ham as thats generally isn't tolerated, just a heads up.
The XYL's 979 does not drift.Agreed. Not all Galaxy radios are drifting pieces of junk like the early 959. Different radios, different versions, different results.
So i probably experienced the extreme as far as cold related drift goes. I spent 10 years living in a school bus in the remote ne washington mountains with only a wood stove for heat. Had a few radios there and i have to say i had the most issues from a pair of 959's when it was cold. Honestly i had no floating/drift issues from my 2950dx gen 2 that i bought after becoming disgusted with the 959's. That was 2013 or so and from what i understand there is a newer version that addressed that issue.The XYL's 979 does not drift.
It should be noted that most radios will drift alittle when they are going from sub-zero to normal operating temperature, which is the case for northern hemisphere mobiles.
May I suggest NO GALAXY. Unless you want to drift all over and sound horrible on SSB. Either find a vintage Cobra 148 side mic or Uniden Grant. If going new the Anytone 6666 I'd a stable SSB radio
That 767 in the pic was a working freebie i never used. I believe i sold it soon after.I have had more issues with Yaesu's than I care to remember.It's why I say YAESU = Yet Another Excuse Simply Useless.I am an ICOM Man now & they have been very dependable.
SIX-SHOOTER
