For Master Chief
Cat Driver
294
4
26
Lake of The Ozarks
I think it was you that had real good directions for putting together a Maco V-5/8. I believe they were more technical than the ones that come with it.
I had run onto them the other day an saved'em. Somehow they got lost in the dang puter and now I don't know where I found'em on here. Could you please direct me to the right post or repost them in this thread.
Thank You Sir,
Ronnie B.
  • @ Geoexplorer69:
  • @ Geoexplorer69:
