??? for Rolling Radios
  • Thread starter Thread starter RugRat235
  • Start date Start date
R
RugRat235
Guest
R.R. what is the difference between the Alpha and the Delta?? Thanks.
CDX235</p>
The difference is the Delatas are in production and the Alphas were taken out about 8mos ago.
The Alpha has a quieter rx, but also less sensitive. The Alpha echo is not the "turbo" echo. Otherwise they are pretty much the same.
Wm. Warlock "671 in Va"
Rollingradios@aol.com
Nat. Rep for XForce/Magna Force Customer Service and Support
</p>
</p>
Are you still the "Nat. Rep for XForce/Magna Force Customer Service and Support"?
  • @ Geoexplorer69:
  • @ Geoexplorer69:
