frequency counter enquiry
KD2GOE
May 30, 2013
952
220
173
44
Buffalo
i picked up a Elenco F-1300 frequency counter and a B&K model-161 transistor beta tester at a swap meet for $50
I want to make sure the frequency counter is aligned. So I was thinking because my Kenwood TS-2000 has a TCXO crystal in it is there any reason i cant take a reading off a test point on that and zero in the Elenco F-1300 frequency counter.?????
and if so any one know where the test point is?
Robb that's a good video but i do not have a feq generator yet. it was one of the things i was keeping my eyes open for.
hmm the Crystal in it is 10mhz and i see TCXO at 10MHz on line for $25
looking around i see some one did this mod..
what do you guts think?
http://rover.ebay.com/rover/1/711-5...0001&campid=5336136228&icep_item=151191552022
I'll stick to my first reply; that is the right answer.
Just learn how to do it.
I use a 10mhz Rubidium clock (+/- 1hz accuracy) to keep my test freq counters right on the money. So do others that work on radios. But if you are going to do it right; then save up a ~$100 to get a decent, used freq counter. The right tool for the right job . . .
I use a Rubidium clock to keep my test freq counters right on the money. So do others that work on radios. But if you are going to do it right; then save up a ~$100 to get a decent, used freq counter. The right tool for the right job . . .
Ok well i don't have the gear to do it that way.. so it is not a matter of "Just learn how to do it." i was hopping the Elenco counter was a good one. so i guess i lost out.
as for $100 for a decent used freq counter all the counters i have seen look no better then what i have now. Every place i look wants $200 to $500 for an HP
Times for me are hard and money is hard to come my over on this end so.
Thanks for the help.
I did the mod with the TCXO and power it up compared it to my TS-2000 it was .000002 off at 10.000 mhz..
Reactions: Robb
