Before you go with the ATAS120 antenna, consider the future.
1. Running an amp, can't do! The ATAS can't be used with much more than 100w.
2. Modifying the whip for a caphat to increase efficiency or use a 17 ft. Telescoping whip like I do for static mobile operating.
3. 60 and/or 80 meter capability.
If none of that interests you then the ATAS antenna does work and is truly plug and play needing nothing more than hooking up the coax cable, nothing more. Go with that one.
This antenna isn't the most efficient of the lot but all the other ones aren't either. Just some are better than others.
