FT-891 Radio
Yes, I have a thru hole Puck mount on the rear roof right above the lift gate. The element I have is from my portable Super Antenna. I want the 56" element, but it's more expensive with oversized shipping. I have various whips from different mag mounts I can weld together to play with. Only thing I NEED to order is quick disconnect for the element.
Reactions: Slowmover
I scored a Little Tarheel II in a gadget trade. I have to buy a whip, as he lost it. Hope to have it installed soon.
I used a 56" inch whip that I made by cutting the top from a 102" stainless steel whip.It works far better than the short whip that comes with them.You can't work 6 meters with that whip but it makes for a much better signal on 10-80 meters & far better on 40,60,& 80 meters.
SIX-SHOOTER
gonna add this little resonator spring.
Some of the Tarheel 2 videos I've watched, mentioned and showed a loading coil be added. I looked at the online manual. It doesn't mention it.
Did earlier Little Tarheel antennas have a need for that coil? The old dude I got the antenna from said he wasn't given one when he acquired the thing, a few years ago. He doesn't know anything about it.
I could make one for it, if it's supposed to have one. Do any of you guys have it with yers?
    6m SUKS today damn...lousy condx...did work FLA but still PB "Pretty Bad" :love: :mad:
    list'n 50.125 USB...working in shop...also 2m FM Simplex freq's 6.52...6.46 ... 6.55 etc..:ROFLMAO::coffee:
    Called you twice Mr. G.......................
    I was look'n your way Evan...was working on some lighting in the garage...you were just "Thr" but w/ fade...you were gone...so did not fire the heater and call :cool:
    Roger that, 6m on the HexBeam is lame.
