Sometimes people will just defend the choice of their radio whatever is out there, and condemning it as gossip.
https://www.dj0ip.de/my-7300/7300-amp-interfacing/
WARNING:
DO NOT 'ASSUME' YOUR 7300 WILL WORK SEEMLESSLY WITH EVERY AMP.
WARNING:
- Some amplifiers use high voltage for keying their T/R relay. These amplifiers will damage the 7300 the very first time you key them.
- In most cases you must make at least one timing adjustment to the transceiver.
- Failure to make the proper timing adjustments to the 7300 USUALLY results in Hot Switching and possible damage to the amplifier.
- Nuff said.
