ft1200dx and scu-17
ahasverus
Dec 2, 2011
69
3
18
i trie to hook up a ft1200dx and a scu-17 but no result
scu-17 : power ok ( usb from pc)
cable (6 pin) (back tx) to input (6 pin) scu-17
like to receive and send RTTY
software FL digi 3.21.83
can i have some help with the configuration
com port 12 installed in the first place
tx set to lsb rtty ???
I think i have to hook the tf (Phone output) to the scu-17 audio input to receive
to send
using the micro (tx) ( 8 pin) to the output output cable 6pin or
jack (3mm)
but there is the question
what belongs to what
i should be much obliged to someone who "let me see the light "
on3bm on qrz.com
  • @ Geoexplorer69:
  • @ Geoexplorer69:
