I decided to experiment with the 9.1unun attached a 18g 30' wire in a sloper configuration. I mounted it 30' up in a tree infront of my building and attached a 30' counterpoise wire to the bottom of the matchbox. Up 12' off the ground perpendicular to the antenna in a downward direction. Conditions weren't that good today but I was able to qso with operator's in Northern California/Seattle, WA/ Arizona. My swr went from 1.2.1to 1.0.1on the atu which helped with Ft-101e. Looking forward to seeing how better it will work when conditions get better.I read the optimal was 17' for counterpoise.. but I had an extra cut to 12' already so I used that. Equal length would be making a dipole antenna..
The frequency is 38.350 mhz
38 lower side band on cb. Without having my license I would get into a world of trouble if I made qso's on 80 meters or any other amateur radio frequency. I like listening alot but won't do it. I use my knowledge/experience/wisdom from my mentor that was an aide to president truman and fellow member's of amateur radio fraternity on 11 meter band until I get my license.Sure you don't mean 3.8350 MHz (aka 80m)..
The other isn't a ham band..
I meant to say 27.385 mhz.Sure you don't mean 3.8350 MHz (aka 80m)..
My end fed wire antenna is 30' long with a 30' counterpoise. It's working good so far. Do you think putting another 30' to the atu ground post will help improve its radiation any better?Not really, equal lengths (44/44) would make it a center fed di-pole.
what you have is a di-pole antenna fed at about 12/44 of its overall length... about 27% , ..... an OCF antenna.
the 17/44 number comes from the "approx" method of feeding OCF's at about 1/3 (17/44 = 38.6%)
I'm listening right now on 27.383.5 mhz and station's are going in from Seattle, Wa/Oregon/Northern Ca/Arizona/New Mexico.27.385
Let me know the next time you can hear my neighbors .
I'll toss something in line .
Plus Montana.27.385
I'm thinking about attaching 3-30' counterpoise wires on the bottom of my 9.1 unun matchbox transformer that's approximately 15' above ground. I have a 29' sloper wire antenna up 35' in a tree. The counterpoise wire will hang down at a 45 degree angle underneath it. Do you think this setup will improve the antenna's performance?Not really, equal lengths (44/44) would make it a center fed di-pole.
