I'm still a bit shaken.
I was adjusting the secondary to get 2kv (carefully) from doubler board when a loud Bang sounded. A cracking noise like an accidental arc. I was a few feet away and stunned. No smoke, no debris, all my caps are intact as are the 2 glass safety resistors on diode stack. No smell either. I run a low value fuse when testing and just raised it from 3 to 4A a few days ago. Standard 1" glass panel mounted. It was blasted inside glass not a simple break like I usually see after an oops moment. I don't see any scorch marks and the HVPS was energized for at least 2 minutes before it went. I guess I should lift the doubler PCB to check underneath, backtrack a little. I'm so close to applying RF I'm getting impatient.
Anyone experience a noisy fuse ?
neil, NYC
neil, NYC
