Hi have been searching the web for some info on channel mod using crystals for the Galaxy 959 and such radios that use the same pc board or pll configuration.
Some info I have is that xtal 3 >15.360mhz is the one to change and either add a 15.810mhz for high or a 14.910 for low channels would this info be correct?
If not can someone supply the correct xtals frequencies to do a xtal mod.
thanks
thanks
