Galaxy 95T
I just picked one up yesterday. Going to run it for talking local on the base. Looks great. Love the meter and the blue lighting.
I mean the way it lights up in the dark. Lettering looks blue. Got it brand new so it was not messed with. What are you guys running your DK at? Mine is 30 all the way up. Would like to raise it to 45 or so but it gets hot as it is.
Im going to run mine for base only. I found a lasko squirrel cage fan at lowes. Run it facing foward behind radio. Works great. 13 bucks
Nope, you wont see much more than that from a low key. In fact, if you see 120, thats actually more than should be there. from 1 watt, 4 or 5 is what should be there. Keep in mind this is NOT a dual-final radio when the amp is taken out of the picture. the amp doesn't need a very high drive to operate effectively.
DTB Radio said:
No, its pretty easy. You just insert a switch inline with one of the amp control lines that plugs in over near the final/driver area. I don't have the specific connector number handy atm.
Can this mod be done to a Ranger 6900f 150 ?
Or a connex 4600 turbo
