I would suggest to maintain 10m usable maybe a 99v2. It has 8 bands and does the 10m normal areas like 28.425 and such. Bells has for each radio a click link showing the freq for each band. The other option is the RCI 2950 with will retain the 10/11m or the Lincoln 2+ which will do 10/11/12 post conversion.
I have and use the 86v and yes it's just CB and uppers and lowers after conversion. Mine has a 10k switch mod but I don't really see the need for that option IMO. The receive is "hot" but when set at like 11am on the RF gain you get good RX without a lot of that hiss noise.
Post tune I'm seeing about 35w peak swing on SSB (I set power knob to hit say 25-30 on my voice peaks to run my amp). I don't really run AM much at all. I did have an external freq counter wires up/in to show me the extra digit over the factory built in one and the clarifier is unlocked. Gives me a little peace of mind. Unit takes about 20 minutes to "warm" up. I run as base only so your purpose may vary.
Received the radio featured in that post as I was leaving town (literally). Tossed it in while getting loaded to replace the 99v2 shown in my post above.
The 99v2 has been destined while for my pickup truck. Will need to send it and amp out to be paired up best as it also needs an alignment.
The before/after of putting the 86v is the clarity improvement in audio. AM or Sideband. SSB much easier to chase last night. I knew the 99 was off, but now I have an idea of how far.
Now, (this is for Dan, ha!) installing the MORGAN 411b bandpass filter cleans it up even further (the WM ClearSpeaker ain’t ALL of it).
Mobile, this is the quietest rig yet.
Ferrites onto every cable of every type.
Antenna feedpoint choke & coax choke at radio. KL203p & 411b in-between.
Antenna mount still lousy, but bonding the (4) door hinges helped move that project along.
It’s a nice radio, CB590. I’m pleased to have it. As in my other posts, it — like the single-final 979 — is a much better fit for a big truck than the 99v2. Your packaging was such it was like-new.
That it also performs so nicely shows me — without question — my 99v2 needs service. (Owned since 2014).
GALAXY DX99v2
Or
Galaxy DX86v
Either one nice to have as a mobile unit.
