Thanks, I will look.The +10 switch itself is pretty simple. Regulated 9 Volts comes in one side, feeds out the other side to pin 9 of IC1, found on the "band" circuit board bolted to the side rail. Has to be a mechanical fault shorting that side of the switch to ground. A wire caught under a bracket and shorting to ground is what I would look for first.
