Thanks guys for the replies.....
I was hunting around for a sledge-hammer and, remembered that I do not own one!...grin...
Anyway, I have the transmit "dead on" and, had the receive the same until the temperature in the room or of the radio changed...
The RECEIVE clarifier is off at 3pm to tune receive ...So, I give up on this for now...
I did read many many years ago that there was a "fix" for stabilization of the freq by using a resistor affixed to a x'tal(??) that, when the radio was turned on, would heat a bit and maintain a near constant temp to that resister and "air" around the x'tal making it "stable"..
Let me shift gears here a moment on 2 other issues....
While beginning to close up the radio, found that my
METER LIGHT is now out
(#^&*&(&$&*!!!)....I can't see the bulb directly or clearly locate a wire(s) that has possibly pulled off the board.....Is there an easy way to locate the bulb - wires, OR change it out?...
Last but, unrelated issue -
I have a
Palomar TX - 150 mobile (transistor) amp that was my deceased friends' amp....I have looked at a schematic on line but, does not indicate the
FUSE RATING...I surmise that it should be a 20 amp fuse but, does anyone know for sure? (below is generic pict I pulled off of the net).
