galaxy pluto
  • Thread starter Thread starter ButtFuzz
  • Start date Start date
The ones over here were also made by RCI.
Here is a Quote from years ago by GRST (Galaxy Radio Tech Support)
Ray worked for Galaxy.
No surprises there then Jeff, i had a feeling they would have been imported elsewhere under the same or different model names.
Funnily enough CRT France also did the saturn,saturn turbo,and i believe a galaxy neptune too, along with crt branded rci 2950's and umpteen superstar models, i believe they did a couple of connex radios too at that time.as far as i know all were ranger built or had copies of ranger boards in some earlier versions.
some mods for it hope they help
Model Modulation AM Power SSB Power
PLUTO VR14 or Cut R249 VR13 VR12
PLUTO (late)VR14 or Remove TR53 VR13(HI PWR) VR16(LO PWR). VR12
All I can say is that the Pluto was the BEST Galaxy made... I had the early LOW BAND and now have a HI BAND by far better then the 88 H/L I have as a base.. Oh yes I run it in the Mobile on a mag mount antenna w/25 watts and have MANY DX contacts with it..
19 div
25 div
14 div
26 div
79 div
and many more
If you can get your hands on a "UNMOLESTED" one by all means do
  • @ Geoexplorer69:
  • @ Geoexplorer69:
