Elastic stop nuts are OK until you need to re-use them.
I just use Loctite. Either the Blue 243 or for a bit more holding power yet still removable the 290 green works well. The reds can be removed but you still may break or strip heads on the softer stuff. I use 262 or 263. The only down side to Loctite is the stuff can be pricey.
