I think herein lies 50% of the solution. No SO-239. No PL259.Shockwave said:. The 10 kw model is supplied with a porcelain stand off insulator with a bolt that connects to "pigtails" on the cable, rather than a PL-259.
Yup. But, then you have the problem of deciding on how much pigtail to leave open and unshielded, to prevent arcing at the feed point and too much open length, so that the wire now becomes part of the antenna. Keep about an inch of exposed center conductor insultation, sealed in clear silicon to prevent arcing and water migration into the cable.I think herein lies 50% of the solution. No SO-239. No PL259.
Where’s a good source of information to properly build a high wattage gamma?
More specifically, the in’s & out’s of which material to chose and why, how to build one that will handle higher power input. I’m aware I could buy one but what fun is that?
I’d like to build one that’ll handle at the very least 5kw.
Which brings the question to the table, the ratings offered by Maco, is that PEP figures or CW/AVG?
the CHOP GONNA ARC WELD THE AIRWAVES hahahahaHAHAHAHAI think I’m gonna buy one from ICA. I think 20kw average power will be more than enough for my mess.
