Bad Photoshop work.who makes this antenna? it looks silly on that little vehicle.
Bad Photoshop work.
Mike
Bad Photoshop work.
Mike
Sloppy Photo-shop. Very sloppy.
I thought the same thing. I blew the image up in a photo editor and looked closely at the piece of the car above the rear window. It appears to go behind the antenna which is an impossibility with the antenna mounted as it is shown. I'm not convinced it is a real picture.
You're just made because car antenna guy out hammed you.
Where did you find that picture on Breedlove's site? I couldn't find it.
And by the way, that picture has definitely been 'photoshopped'. Take a close look at the driver's side of that rear glass, and also the 'spoiler' line at the top of the window just over that 'third' brake light. Want a little clearer view? Try 'reversing' it or a 'negative' view. Close, but no cigar.
