WOW! I just looked at this thread for the first time and read it all. :headbang For a minute or two I thought I had the television on and tuned to Comedy Central. :laugh:
Carry on carrying on!
Well, it is very obvious this post was started to make sales for the mentioned product. How do you guys think that PC is gonna run next to the Heathkit SB-220? How many keys before the mouse locks up? People, there are much easier ways that cost less if your goal is Hi-Fi AM. I work 75 meter AM all the time and you'll never hear this gadget used there.
I am the person that designed the Mauldulator. My original interest in this circuit was exactly for 75M AM where I also operate. I do not operate on "the bowl", but I like tinkering around with MMM on projects like this.You will eventually be hearing this "gadget" on 75M AM, if only from my station. It is incompatible with my Johnson Valiant because of the voltages involved. It is incompatible with my Icom 706 which uses a balanced modulator stage to produce AM.
My long term goal is to use a Software Defined Radio board to put out about a 1 watt signal. I will then feed a home brew amplifier that can be "mauldulated". That amplifier will have an output of about 10-15 watts which will then drive another amplifier.
I will never run 200% modulation on this thing, although it can certainly do that. I may probably use up to 130%. It is true that most CB receivers can have unexpected results if the positive percentage is too high, and if the bandwidth is not paid attention to. MMM uses two receivers when customizing his audio going into this thing. He uses a stock Cobra 148 or Cobra 29 as well as a receiver with a wider pass band. He then adjusts it for the sound that is pleasing to him on both.
I use rack mounted equipment right now for my 75M AM stuff. I had that stuff going before I even knew about all this fancy software stuff. When I designed this thing I had no intention of using the computer because I did not even know about those audio processing programs. I admit that I like the idea of audio profiles that can be saved and loaded at will. I will probably not mess with the computer stuff until the latency is reduced. I like monitoring my AM signal in real time and the delay is too disorienting for me.
That being said, there are several stations that run computers in a high power environment. What do you think a Flex Radio is? MMM uses a pretty big box routinely and uses the computer just fine.
I think that a point is being lost in all of this discussion that I would like to emphasize. It is true that 200% positive modulation can be created, and that "high fidelity" can be achieved. The point I would like to make is that the Mauldulator presents you with a blank palette. What you put in is what comes out. Your audio is not reshaped by intentional limits of the radio or the undesired limitations of a modulation transformer. This functionality is important to some people, and not to others. If it is not important to you, then you don't need to buy it.
It also needs to be pointed out that broadcast AM stations are allowed to run 125% peaks, and they do so routinely. Furthermore, asymmetrical modulation is nothing new on the ham bands. During the peak of AM operation in the 50s and 60s on the ham bands, some hams played with so called "ultra modulation" and "negative cycle loading". Both of these implementations were basically the forerunners of today's negative peak clipping modifications on CB. While this will indeed result in signals with over 100% positive peaks, the cost is clipping of the negative side which causes distortion. Check out some of the ham references to this at The AM Press/Exchange Issue #65
Of course asymmetry is distorted by definition, but in the Mauldulator, the positive side of the audio is merely a larger version of the negative side. It is not clipped. I guess you could call this "less distorted distortion".
There have been critics insisting that you can duplicate the fidelity of the mauldulator on a simple radio using a proper microphone, or feeding a ham radio at the back in the auxiliary inputs. I would really like to see this.
Tink
Three easy steps to excellent CB Hi-Fi audio without a Mauldulator or PC connected to your radio.
1) Buy a Joemeek ThreeQ and a decent XLR mic.
2) Buy a cobra 148 GTL.
3) Connect the output of the Joemeek through a coupling cap to the base of the series pass modulator in the 148GTL.
No internal limitations of the CB. No modulation transformer. Most of all, no PC for simple audio processing. Notice most Flex radios recommend the use of specific Intel motherboards? Some even offer an RF proof PC as an option with the flex radio.
Let me know when you're going to be on 3.885 and I'll be happy to demonstrate Hi-Fi AM using a ricebox rig, 575M6 mic, and $10 worth of Radio Shack parts used to modify the transceiver and mic.
Tink,
I know what Hi-Fi is and can easily achieve more bandwidth with flat response then we normally find on the broadcast bands. Once you know how to spot bypassing caps, coupling caps, and negative feedback loops in the audio chain, this is no difficult task.
Years ago I use to modulate radios from the outside using Hi-Fi stereo audio amps. Then I learned how to modify the radios internal audio stages to achieve the same results. It's a simple audio amplifier not rocket science. With a signal generator, a scope, and a schematic results are easy.
I enjoy AM and sharing what I've learned with others free of charge. At the recommendation of WA1HLR and W2NBC I will be posting one of my more popular modifications on the The AM Window site. The TS-940S is a very common radio that can be purchased used inexpensively now. You probably know they sound fairly bad on AM stock.
You don't need to travel all the way to Connecticut just to see mine. You can copy my modification and have you're very own. You can sweep it, look at it on the spectrum analyzer, and scrutinize the entire modification if you wish. Bottom line is it will provide every bit of fidelity you can get by modulating a rig from the outside and you can prove it to yourself.
The best part is my modification does not require the use of any external equipment that could introduce new places for RFI to migrate into the audio chain. Once the moderator on the amwindow site uploads the modification, I will post the links here. My documentation includes step by step instructions with photos. It renders old school outboard modulators obsolete by using Hi-Fi low level RF modulation as opposed to restricted IF modulation.
One main thing you seem to overlook is that there has never been a CB radio receiver manufactured that can reproduce lower then 200 cycles and higher then 4 KHz. Typical receiver response is 300 Hz to 3 KHz. At least on 75 meters there are receivers that can reproduce Hi-Fi. It's not very practical to think that everyone is going to modify their CB receivers to pass this bandwidth that essentially gets wasted on 11 meters.
I heard Motor Mouth on 6 today and all I can say is Ive never heard a better sounding station. If his stuff he sells sounds half as good I would be impressed.
[URL="http://www.11meteroutlaws.com/viewtopic.php?f=39&t=275"]hxxp://www.11meteroutlaws.com/viewtopic.php?f=39&t=275[/URL]
