I checked the MV1Y diode on the 2nd final, checks as it should. It matches the other MV1Y diode.
Just for giggles, I replaced the 2nd final.... everything is perfect now. Bias currents on both finals are stable, and adjust as they should. Was able to dial everything right up per the service manual. I put the suspect final on my transistor checker, and it seems to check fine, but maybe it has leakage at a junction? Truly odd.
~Cheers~
~Cheers~
