I also wanted to comment about those who think Hi-Fi on 11 meters creates an interference problem as a result of wider bandwidth. Hogwash! This is the least of your problems in terms of wide band signals on this band. With 10 KHz channel spacing it's not going to be the Hi-Fi guy giving you bleedover.
Those that run Hi-Fi are concerned with quality transmission and almost never drive their audio into RF cutoff. It's the guy with the 16 pill and clipped AMC with a power mic that causes the real bleedover issues on this band. It's more complex on 75 meter AM. To those who are offended there, I invite you to move away from the AM window and stop complaining like the so called net on 3872.
I do have some sympathy for those who complain about Hi-Fi SSB on 80 meters. SSB was never intended to reproduce Hi-Fi do to it's restricted bandwidth. While it does improve sound quality, SSB receivers have much narrower and sharper filtering. Making much of the effort wasted unless the receiver has a wide filter. At least with AM the wideband operation is mostly confined within a 20 KHz slice of spectrum on 75 meters.
