Hello, I've been lurking on this site for a couple years or so. This is my first post. I haven't been able to find the answers I've been looking for. Or maybe I did but they were over my head. So I'm hoping that someone here can dumb it down enough so that even I can understand it.
If you take a 1/4 wavength antenna, (at 11 meters) like a 102" mobile whip (108" times a velocity factor of approximately 95% equals about 102.5") and mount it on a 102" metal mast, you will have more or less created a 1/2 wave dipole (I think). If you then remove that whip and mount a 1/4 wave ground plane in it's place, it seems to me that you now have a COMBINATION of a 1/4 wave ground plane (50 ohms) AND a 1/2 wave dipole (73 ohms). The mast would still be a part of the antenna structure, right? Most antennas seem to be modeled in free space and don't include the mast. What effect does a big chunk of metal mast have on the properties of the antenna? Would the impedance be somewhere between 50 and 73 ohms? Would a different length mast that isn't resonant be worse than one that is resonant? Should the mast be isolated? Even if you isolate the mast but run a ground wire from the ground plane to a ground rod, wouldn't that also be a part of the ground plane assembly? I bought a 1/4 wave base antenna and I'm wondering if I should isolate the mast or cut it to a resonant length. I'm thinking I should cut the mast to 102 inches or so, but then I wouldn't have enough clearance between the radials and the roof. A guy from South Carolina on YouTube made a 1/2 wave vertical dipole from copper wire and PVC pipe and then added two ground plane radials made from wire and had a good match and could talk skip on it really well. What am I missing? What do I need to know? Thanks!!!
