Groundplane / Beam interference ??
  • Thread starter Thread starter Desert Rat04
  • Start date Start date
Hello Desert Rat:
How far apart are the two antenans. The closer they are they the more they will effect each other.
One good way to tell this is to take down ground plan antenna and see how the Jo Gun II does, measuring local S-Meter readings and field strength tests.
Then put the ground plane back up, and measure the beam again, what is the difference?
You can monitor incoming signals on the ground plane, while swinging the beam around, you may see received signals slighty move the S-meter a needles width, thats not a big deal.
But anymore may indicate the antennas are too close together.
Jay in the Mojave
http://www.a1antannas.com
Desert Rat04 said:
:?: I have a Jo Gunn Smokin Gun ll and a Maco V 5/8 ground plane, around 20 to 25 feet apart.. Approxamate same hight .. The guy at Jo Gunn says beam is phasing with the ground plane therefore not allowing any back or side rejection. CB buddies are killing me about this .. HA! What do you'all think ?? Is the Jo Gunn guy giving me a line ??
Thanks, Desert Rat :?
    Noooooooooooooooooooo
    bone1141 has left the room.
    GM Radio Maniac's....
    6m SUKS today damn...lousy condx...did work FLA but still PB "Pretty Bad" :love: :mad:
    list'n 50.125 USB...working in shop...also 2m FM Simplex freq's 6.52...6.46 ... 6.55 etc..:ROFLMAO::coffee:
