Translation by google translate from I guess Russian. I had to tell it to detect language:
"Visually ANYTONE 555, and by then the same functionality. In the FM-modulated weak, needs some work. minimum step 10Hz (synthesizer). Receiver in all modes shown itself to good hand With modulation can work (there mumbling there fonit). As you would expect from a Chinese monsters. In general when compared to what is available at the moment, like as nothing can live."
" A built-in reverb, bumper (RB) (which is included in time and periodically freezes, but if you switch off, then everything is OK), USB, LSB, AM, FM, CW, power control mode, PA (speaker can be derived under the hood and learn about girls from the comfort of a car when it's cold)), built SWR meter, and the value can be displayed in the figures on the main LCD display. In general the unit on a solid three +."
I think if you wanted to jump through enough hoops you could get one.
I will also bet pretty much anything that Kenwood has not given an ounce of authorization to use their name or logo.
