Help identify this base amp or resistors please!
It has its own built-in 20W dummy load. You'll notice that there's 2-25 ohm, 10 watt power resistors in the back. They are tied parallel.
-Exit
Two 25-ohm resistors in parallel would be 12.5 ohms. If you put them in SERIES, you'd get 50 ohms, and if the resistors are the ones I think they are in the picture, they do appear to be in series, not parallel.
Hey guys I havent been on the site for awhile but managed to figure out the resistor values much harder ways!
I do really appreciate the help though and now that you have confirmed they are 10ohms I feel even better!
I am currently waiting on some tubes to get here sometime next week I hope. I have 2 other tube amps I would like to freshen up but i need to get a tube tester or somebody that has one I can use to check about 30 6lq6!
