Help! RCI 2950 won't go into CB mode
Turp
Apr 16, 2012
20
S.E. Louisiana
I just hooked up my 2950 last night, and talked on Ch2 all night. Got to work tonight, and I can't get it into CB mode. Its on AM, and man button will not switch it into 1-40. When I turn the power on it goes straight to a frequency and will not switch. Am I not doing something right?
  • @ Geoexplorer69:
  • @ Geoexplorer69:
