Where to start with this???? So is the 2SC1969+NPC mod and strapped/volted final? LOL.....Get your pet rock out of the attic and your bell bottoms too! LOL
The only way it could get any worse is to install a fet in the final and then do the NPC mod! LOL
To add insult to injury you have added talk back to this monster of funhouse modifications!
Man, I can guaranty your radio is a splatter box POS! Your modulation is dirtier than the bathrooms at a Greyhound Bus Station in a major city!
99% of the talkback mods by themselves cause issues. That is why radio's that come from the OEM with talkback normally have their own separate audio chain just for talkback today on modern radio's that is separate from the rx/tx audio chain. Put the right final back in it. Undo the talkback. You would have to really have to be full of your self and love the sound of your own voice to pay good money to add such a worthless mod to a radio!
Since this is an AM only radio if you have a really good tech do the super swing and the modulation is staying bellow 120% and the knucklehead added a beefed up 54Mhz trap filtering you can keep that I guess. If the filtering is good though you and your Tech and I use that term loosely will be disappointed since you will not have a lot of fake meter swinging harmonics anymore. Play with cap values in the audio chain to get the bottom and top end improved just a little bit. Add a SL41 mic and a 1,2,3 transistor amp.
What you have right now is not a radio it is just a noise toys.
If it killed the stock mic it sounds like power is being shunted up to the dynamic element which will either lock it up giving you fairly low performance and modulation or it will just kill the mic element.
What type of stupid mod gives you a radio that has to have the mic gain turned down to nothing practically!!! There is not a single radio out of the box that will behave that way all of them can be used with the mic gain full tilt. Even if you put power mic on it with the mic gain turned up it will still work properly. It is only when people butcher them that you end up with this sort of idiotic performance. It is as stupid as a car that you could only use 1/4 throttle or 1/4 of the brake travel without the car malfunctioning!
I am not a fan of NPC/Super Swing. That said if you keep the carrier suppressed and filter out all the garbage before it gets out of the radio it can be ok on an AM only radio.
ditto. i hate talk back. if i want talk back ill go talk to the wife. plenty of talk back there
