I purchased a used motorhome and it has a lame little (2foot) antenna mounted on the top of the aluminum ladder on the back of the motorhome.
The coach is all fiberglass so a ground plane to use a good antenna will be a challenge.
I don't need a wide banded antenna... I also dont need antenna to handle handle high power since I do not want to run an amp..
I want good ears!.
I really dont have antenna size limits, BUT I think if I get carried away, antenna MIGHT hit bridges, hehehe .. Motorhome from floor to top of ACs is 12 feet, and I THINK I can get way with mounting the 10K so that the coils are with the roofline or a little above. And have enough antenna wire sticking up above ACs that I might be OK.
Is looking into getting a Predator 10K overkill? Since I will not use it for out of band freqs OR high power I think it might be overkill? My other concern is the fiberglass motorhome... NO GROUND PLANE, this is what concerns me the most?
What route should I try? Am I off base and I should look into something else?
thanks!
I want good ears!.
thanks!
