Retevis is giving away Radios for the New Year and Every Member is Eligible. Click Here to see the details!
Moleculo could you grund the ladder to the frame? Just use a good type coax? If you dont tow a car you could run small pipe coming off a reese hitch. Slide on a towing hitch to the conector and run the pipe from there.
What you're doing is turning the whole frame into your groundplane. On a motor home, it's a little too far from the antenna, but everything is a compromise in this situation. Also, the ladder will give it some counterpoise.
I would opt for the mirror mount, that way you could run a larger and better antenna, like a Wilson 2000 trucker. A 1' or 2' fiberglass antenna ain't gonna do squat for you.
I was look'n your way Evan...was working on some lighting in the garage...you were just "Thr" but w/ fade...you were gone...so did not fire the heater and call
