ok on my Cobra 2000 gtl i need help or guidance on how to balance the power output from channel 1 to 15 I'm seen close to 15 watts rms
the higher I go on freq power start to drop I've done these 2 mods but no change=
IC-5 tx-mixer change R190 from 100 to 47ohms then put a 330ohm from pin-5 and this one=ssb low power on IC3 balance modulator remove c207=47pf and change R206 from 270k to a 35k also when i try to balance the power output am starts to drop any tricks to balance it out like a happy medium thanks
