HF vertical
FWIW (not much)
I once had the opportunity to listen to stuff on an 80meter two element quad. It was day time, quad pointed north, so only really heard a LOT of Asian noise. But, @#$, was it loud!
Our original 43 foot MULTI-BAND 10 to 160 meter VERTICAL
with fold-over mount $469.00
(Over 1,500 of these sold since 2004!)
33 foot multiband vertical - 12 to 80 meters
includes balun plate and foldover mount (free-standing) $329
NEW! - 24 foot multiband vertical for 10-40 meters with
balun plate and foldover mount (free-standing) - $275​
These Multi-Band Verticals are a vertical element with no traps, or coils, it is a non-loaded radiator made with 6063 T832 commercial drawn aluminum tubing. Big 2 1/8" bottom section tapers at the top for flexibility and strength, 2" heavy duty oil filled cast nylon base insulator and 14" long base tube included. This Antenna is made for multiband operation and can be used with a remote antenna tuner mounted at the feedpoint or a 4 to 1 balun at the feed point if coax is used. A minimum of 16 radials is suggested. This is a very heavy duty vertical that can be guyed or free standing. Can be ground mounted or mounted on top of your tower.
Balun mounting plate now included.
(Recommended balun for this antenna is the ZF-MB-5k from Array Solutions.)
Picture on the left is the base section shown with optional balun.
Click on picture for larger image.
Click here for a picture view of the installation of the balun mounting plate.
See what hams have to say about this antenna on EHAM.net.
Download or view installation tips for this antenna here. PDF file
http://www.zerofive-antennas.com/
__________________
That's how I roll!!
So your'e saying you have one of these ???
  • @ W4KVW:
    6m open
    Bunches of TX+ LA / OK / MS /CO /AL / NM AND OTHERS...good sigs...op in MS on squalo was over S9 :cool: (y)
    Texas and Lousiana very strong here....
