Here's what happens to a SPT500 if both clamps are not tightened, or loosen up. Evidently the top clamp loosened up to the point the winds got hold of the radials enough to twist the whole mount. You can see the J match touching the radial ground plane elements. Needless to say the SWR is off the chart.
Bummer. Now I have to rent a lift and see if I can get it back in alignment...and tighten the clamps with some more lock tight.
